going from 84 700r4 to a 91 700r4 in camaro help
Old Oct 6, 2013 | 04:16 PM
itsdeenoo's Avatar
Car: anything with wheels
Engine: 327
Transmission: t5
Axle/Gears: ford 8.8 4.11
okay i have a 84 camaro with 84 700r4 that i took out getting a 700r4 out of a 91 will everything match up or what will need done please help anyone
Old Oct 6, 2013 | 04:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: going from 84 700r4 to a 91 700r4 in camaro help
They both need to be from V8 engines. The torque converter spline count is likely different. So would need to use the '91 converter. IIRC, the spline count changed from the '84 to the '85 MY.
Will need to swap the VSS out for the cable drive unit. And possibly swap the drive VSS gear.
RBob.
Old Oct 6, 2013 | 05:25 PM
itsdeenoo's Avatar
Engine: 327
Transmission: t5
okay so can you or anyone tell me how i swap the VSS out for the cable drive unit. and swap the drive gear thanks!
Old Oct 8, 2013 | 08:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by itsdeenoo
can you tell me how i swap the VSS out for the cable drive unit. and swap the drive gear
Undo the bolt , remove the VSS , install the cable drive unit and it's driven gear
https://www.thirdgen.org/forums/post...382-post9.html
can you tell me how i swap the drive gear
Remove the tailshaft housing ( 4 bolts ), remove existing drive gear ( green gear in pic ) and replace with the gear required.
Make sure the gear retainer clip shown is installed correctly into the output shaft otherwise the gear will spin and you will have no speedo
BlueIroc-Z
Jun 9, 2019 03:22 AM
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
