LT1 T56 behind an LS based engine theory
Old Oct 26, 2013 | 10:18 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Ok so I have an LT1 T 56 that won't work with an LS based engine because GM decided to have shorter cranks and the T56 shaft won't reach the crank. So they made the newer (98-02) t56 with a longer shaft. To do the swap properly you need to change the input shaft for a longer one and change the front case and bell housing. Along with all the hydraulics. Very expensive proposition but so is buying an LS1 T56
Theory: #1 get some sort of a crank spacer that would bolt through to the crank on the trans side to extend the pilot bearing out to reach the LT1 shaft
Theory #2 swap only the input shaft if possible and use the rest of the LT 1 parts.
Problem with both swaps is the bell housing isn't able to use all of its bolt holes to mount to the LS engine. 1 missing I believe.
Discuss!!!
Old Oct 26, 2013 | 10:31 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: LT1 T56 behind an LS based engine theory
Clutch release differences are what makes the fitment less than straightforward.
Purchase of the parts - sale of the others = less than a one-off flywheel.
Old Oct 26, 2013 | 10:40 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Tick performance might have a cost effective solution
Was just on their site their rebuilds/upgrades are real reasonable. Seem to know their stuff
midge54
Dec 27, 2019 04:14 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
