4th Gen Rearend Swap
Old Oct 29, 2013 | 11:56 AM
XxSLeEPyJuiCExX's Avatar
Car: 1984 Camaro
Engine: built 305 V8
Transmission: 5 Speed
Hey fellas, just got my 1984 sport coupe camaro back from a friend who swapped a built 305 into it, and i wanna upgrade my rearend to a posi. How do i swap a fourth gen rearend into mine, im not that mechanically savvy, and any help would be wonderful. cheers!
Old Oct 29, 2013 | 12:24 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 4th Gen Rearend Swap
Unbolt 3rd gen rear end, bolt in 4th gen rear end.
They are a direct swap.
Old Oct 29, 2013 | 12:40 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
At most will need custom e. cables and you if you end up with an ABS rear you will have to swap one of the hard lines from the old rear to the new one. other than that I swapped mine in about 3 hrs.
Old Oct 29, 2013 | 12:59 PM
kcaalarcon's Avatar
Just as a heads up, 4th gen rear is wider than 3rd. Except for that all you need to do to swap them is undo brake lines. Unbolt torque arm, 2 bolt, control arms, 1 bolt for each side. panhard rod, 1 bolt and sway bar, 2 u bolts. and take out the driveshaft. Pretty easy swap
Old Oct 29, 2013 | 03:12 PM
big gear head's Avatar
4th gen rear ends have disc brakes. You probably have drum brakes. That's probably going to be your biggest issue.
Old Oct 29, 2013 | 07:16 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
to me this was a plus.i swapped in a 2000 disc brake rear and the brakes seem to work fine.i got park brake cables from flynbye.im in the process of swapping in the lsi front brakes.
Old Oct 29, 2013 | 07:24 PM
a plus
No doubt!!
But, it does take a certain amount of "custom" engineering to get that handled.
I'd agree though, the rear end swap itself is beyond eeeezy. Almost doesn't even qualify as a swap. (like 305 ->350) It's the brakes and the wheels, getting em PERFECT, is where the finesse is.
Old Oct 30, 2013 | 09:02 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Swap the proportion valve. If you dont, your rear brakes will barely be doing anything.
Old Oct 30, 2013 | 11:02 AM
Car: 1984 Camaro
okay well i do understand the swap part, the only yhings im no good at is the ebrake, how does it connect to the rear. and where is the proportion valve located at. Thanks guys.
Old Oct 30, 2013 | 11:07 AM
Car: 1984 Camaro
Alright well as an update, my rearend is drums and i think it might be easier to just find a posi out of an iroc or something, problem is i know that some 3rd gen rearends are not posi track, just like my friends 5.0 89 RS. So what rearends are posi, how would one check? thank you all for your patience im not a more mechanically inclined third gen owner. in other news , how does the emergency brake work lol
Old Oct 30, 2013 | 01:41 PM
irocdis's Avatar
How much wider?
Old Oct 30, 2013 | 01:48 PM
kcaalarcon's Avatar
I never actully measured but I think 2.5 inches maybe. Just a guess tho cuz it was almost the same as my stock axel with 1.5 spacers
Old Oct 30, 2013 | 03:28 PM
3rd gen limited slip rear ends had the Auburn differential. If you find one it is probably going to be worn out, and they can not be rebuilt, so you would be no better off than you are now. Installing a new Eaton Posi or Yukon Dura Grip would be a better idea.
Old Oct 30, 2013 | 03:48 PM
kcaalarcon's Avatar
He is right, it would probly be smarter to do that if all you're trying to achieve is having posi. Plus a new locker would probly be stronger
Old Oct 30, 2013 | 09:19 PM
Car: 1984 Camaro
Alright, ive seen plenty used rearends on the local classifieds for like 250 bucks but they are the stock ones out of 3rd gens, do you guys think i could find a 4th gen rear for cheap? or could i find an aftermarket one for cheap used
Old Oct 30, 2013 | 09:40 PM
kcaalarcon's Avatar
I got mine for 300 and it came setup with ls brakes, 3.42 and a still pretty well working possi that's not worn out to the point of not functioning, out of a 4th gen. I could be wrong but I think some of the 4th gens, maybe ws6 had a stronger steal diff. As far as getting an axel out of a third gen they can very so widely from having no locking diffs, drum brakes, and some 2.73 gears. If you could find a 4th gen rear for cheap that's not super well used then go for it. Otherwise I would just buy a posi unit or save up to buy and aftermarket rear cuz the stock 7.5 inch 10 bolts are kinda weak
Old Oct 30, 2013 | 09:46 PM
zenish's Avatar
Engine: 305 tbi
the six cylinder cars usually have lower gearing and are the same strength.
Old Oct 30, 2013 | 09:53 PM
kcaalarcon's Avatar
From my understanding anything ranging from a Chevy truck to a 3rd. Or 4th gen f body all have the same exact axle. Different gears and lockers but overall same. Didn't one of the 4th gen anniversary bird have a hardened steal diff tho?Could be wrong tho
Old Oct 31, 2013 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the 10-bolt sticky at the top of the page.
JamesC
Old Oct 31, 2013 | 07:21 AM
If you do a 4th gen rear end get a '98 to '02. They have the Torsen differential which is far better than the Auburn.
Old Oct 31, 2013 | 11:11 AM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
I believe (based on some research, and having both) F-bodies got the 7.5" 10 bolt, the trucks got the stronger/larger 8.5" 10 bolt. Parts will not interchange.
Old Oct 31, 2013 | 03:02 PM
S series trucks used the 7.5 rear end.
Old Oct 31, 2013 | 03:19 PM
kcaalarcon's Avatar
I have a Sonoma and a full size blazer that ik for sure have the 7.5 but idk about the other full size trucks. He is most likely right and they have the 8.5 but I couldn't tell just from glancing at them
Old Oct 31, 2013 | 05:55 PM
Full size Blazer and full size trucks did NOT have 7.5 rear ends. The smallest rear end that they had was the 8.5.
Old Oct 31, 2013 | 11:20 PM
kcaalarcon's Avatar
Not to argue, in most cases your probly right but I have an od-ball one and have replaced the diff in it and it is defiantly a 7.5. Sorry
Old Nov 1, 2013 | 06:17 AM
Not to argue, only to state facts...
Then you have the only one in existence like that.
Either your truck isn't a full-size (which it isn't if it's a Trailblazer, S, Colorado, etc.), or it wasn't a 7.5" rear. That's the only 2 possible explanations.
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
