Bellhousing bolt idea.
Car: '87 Trans Am GTA
Engine: 5.7L 350cu.
Axle/Gears: Stock
So it took me two terrible days to wrestle my 700r4 out of my 87 trans am, mainly the top two bellhousing bolts. As I am inspecting everything it occurred to me that the crossmember is holding the transmission in the same way those bolts are. So my idea is to cut the heads off of the top bolts and use them more like pins... Is this a terrible idea? Anyone done anything similar?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Bellhousing bolt idea.
That means you only have 4 bolts and the side dowels holding the transmission to the engine. The bellhousing is weak enough as it is. Using all the mounting bolts to hold it firmly is recommended.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Those bolts are not hard to get too. Remove the trans crossmember and lower the trans a little being careful not to break the dizzy cap on the firewall. Use a couple long extensions and they are cake to get too.
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
This ^^^^ bunch a long extensions and mabey a swivel for the one on driver side that's a bitch
Car: `86 SS / `87 SS
Don't screw with something that important if it works as designed.
I've had bellhousing bolts loosen and the snout half broken off off the converter in an otherwise healthy trans.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Anyone tried cutting a small access hatch into the tunnel so the bolt can be reached that way. Then cover it with a panel and gasket. If you're only going to do it once then to too useful but if you'll be monkeying with the engine/trans a lot it may be worth it.
What's even EEEEEZIER, is to just stand next to the car, and reach down in there with a short box/open-end combo wrench.
They're the EEEEEEEZIEST ones on the car to get to. Don't have to jack the car up, lay on the floor, or anything.
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Sofa is right, you are making this more difficult than it needs to be.
Engine: 4++,350 & 305 CIs
I have never seen so many people work so hard at trying to make a simple job hard as some people on this forum. (well other than D.C.)
Car: 1971 Camaro
Engine: 427
No doubt. Guys on fb are defending "fuel pump access doors everyday"
removing carpet and hvac parts, cutting a hole, go to hardware store get piece of metal, screws, permatex, trim metal to make a patch, hope the hole was in the right spot, and then putting it all back together after?
Yeah, that's easyier!
Heck, if it's a pain just pull the hood off so you can comfertably get to the bolts from the top.
