swap a 9 bolt for a 10 bolt
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Axle/Gears: 10 bolt with 3.73
I have an 86 trans am with a 9 bolt with 2.77 gears. My take off sucks with highway gears. I have an extra limited slip 10 bolt with 3.42 gears from a 99 firebird. Neither have traction control. Is it a direct swap? It looks like it is. I have read that the 99 axle sticks out a little which I dont mind. Is there anything i would have to change? Any insight? Thanks for any input.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: swap a 9 bolt for a 10 bolt
The 10-Bolt FAQ sticky should give you the info your require.
JamesC
JamesC
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
I read the sticky and the only difference I read was it has 28 splines instead of 26. Which shouldnt be a problem.
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Aug 25, 2015 12:54 AM
