Trans fluid leak
Old Feb 27, 2014 | 11:32 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Trans fluid leak
I replaced the radiator in my 87 and now I'm leaking trans fluid around the bottom radiator connection. I've tightened it down as much as I can but I'm still getting quite a bit of fluid leak. Is there a secret to attaching these connectors? Is there supposed to be a washer on the connector to seal it? I didn't see one when I removed the old radiator.
Steve
Old Mar 1, 2014 | 09:20 PM
morgsie's Avatar
Re: Trans fluid leak
Connections should be flaired. No amount of threadsealer or o-rings will stop leaks. You most likely crossthreaded it when reinstalling. Sometimes the female connector on the rad is removable, it may be leaking from that.
Old Mar 2, 2014 | 08:29 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Over tightening a flared connection can sometimes put a small longitudinal crack in the flare of the hard line.
Take the connection apart and look at it carefully.
jklein337
Sep 19, 2018 06:23 PM
maroe624
Apr 16, 2017 08:29 AM
cstrobel65
Aug 15, 2015 10:19 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
