Back lash not right or weak gears?
Old Feb 28, 2014 | 08:08 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Any thoughts on this? These gears have only been in for maybe 6 months. It a 10 bolt. Behind a 5.3 and 4l60e
Old Feb 28, 2014 | 08:36 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: Back lash not right or weak gears?
Are those pieces sheared off I see? Looks like it was a surface defect that cause a crack to propagate.
Old Feb 28, 2014 | 08:43 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
It looks as if someone took a grinding wheel to them. Its only 7 teeth the rest look ok but they are dark spots in that area.
Old Feb 28, 2014 | 09:40 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Who built the rear? Looks like it was never patterned and shimmed. Maybe someone just replaced the pinion and ring gear and never set it up correctly? I'm also curious to know what brand the gears are.
Old Feb 28, 2014 | 10:18 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
I local shop, Corky's performance. I had them upgrade the gears to 4:10s, and the gears, I believe are the summit racing gears.
Old Feb 28, 2014 | 10:40 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Well since it is apart now, you might as well throw some paste on the gears and look at the pattern. That will tell you if the shop set them up correctly or not.
Old Feb 28, 2014 | 10:43 AM
red rock's Avatar
Car: 1987 iroc
To me, it looks like the pinion is too close to the ring gear, that's the wear on the crown or top of the gear. And also the backlash needs to be increased to move the pattern more towards the center of the face. In fact, it need to be patterned and set right. Maybe there was a burr under the ring gear and it's not set on the carrier flat?
Old Feb 28, 2014 | 12:32 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
This might just be the 2nd sign telling me to do a 8.8 swap.
Old Feb 28, 2014 | 01:24 PM
GILLIGAN's Avatar
Car: 1992 RS
Engine: BLACK&DECKER AQUARIUM PUMP
Was there metal in the rear end?
Old Feb 28, 2014 | 01:47 PM
red rock's Avatar
Car: 1987 iroc
A swap is always an option, but i would resolve the gear change problem with your builder first. If he did a gear change swap and didn't take the time to set up a proper pattern and check the tolerances, I would say he owes you something.
Old Feb 28, 2014 | 03:21 PM
big gear head's Avatar
The teeth on the ring gear were ground down so that the block in the center of the differential could be installed. The ring gear is too thick for the block to go in without grinding a few of the teeth down a little. It's no big deal. A very comon problem, especially with the smaller rear ends.
Old Feb 28, 2014 | 03:30 PM
GILLIGAN's Avatar
Car: 1992 RS
I have seen that before also that why I was wondering if any metal was found in the diff.
Old Feb 28, 2014 | 04:35 PM
If it was done right then it should have been done before the differential was installed in the housing.
Old Mar 1, 2014 | 03:37 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Maybe it's because your car is upside down
Haha or the picture is. I've heard of that- grinding down the teeth to slip the paddle into a torsen diff.
BigGearHead nailed it.
Old Mar 3, 2014 | 11:58 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Didn't appear to be more than normal
Old Mar 3, 2014 | 12:04 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
I never heard of grinding the teeth either, but I went to a closer shop to my job and they said the same thing. That sometimes the teeth have to be grind a little to put the block in. But I'm pretty sure I took it out the spun the gears by hand and discovered this but oh well.
Old Mar 3, 2014 | 12:15 PM
A 3.23 gear set has a thin ring gear and the block can be installed without grinding. When you get to gears like the 4.11 the ring gear is thicker and sometimes needs a little clearance to get the block in. With other differentials that have a round cross shaft you can grind a flat spot on the shaft to get enough clearance to install the c clips.
hectre13
Aug 26, 2015 08:17 AM
justin57
Aug 20, 2015 07:05 PM
cstrobel65
Aug 15, 2015 10:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
dhonda200
Aug 11, 2015 11:50 PM
