Wheels turn?
Subscribe
Mar 24, 2014 | 04:28 PM
87iroc is up on jacks an went to tighten up the wheels an they are turning theses are the back ones trans in park an driveshaft is not turning at all. axel is a BW 323 posi. can someone tell me what is going on please. Thanks
Reply 0
Mar 24, 2014 | 05:53 PM
Re: Wheels turn?
Posi is wore out
Da Heights has changed some from when I used to pass through there a lot... used to live in the orphanage right down the road from there
Reply 0
Mar 24, 2014 | 08:54 PM
Re: Wheels turn?
Christ, da heights huh. No not much has changed. It was a dive when i lived there as a kid and it a still a dive whenever i visit my parents. Yeah You a Bloom trojan too?
not uncommon for the posi to be wore out on these cars.
Reply 0
Mar 25, 2014 | 01:03 PM
Re: Wheels turn?
The Auburn has lost it's grip. Time to toss it in the scrap metal pile and put in a new Eaton Posi or a Yukon Dura Grip.
Reply 0
Mar 25, 2014 | 02:15 PM
Re: Wheels turn?
Just snug the lug nuts while the car is in the air. Then once on the ground torque them in a star pattern to 100 ft/lbs. Don't forget to torque them, if you lower the car and don't torque them right away, place something, even the torque wrench, on the drivers seat as a reminder.
RBob.
Reply 0
Mar 25, 2014 | 03:18 PM
Re: Wheels turn?
Or set the parking brake. Honestly, if it still spins both tires when you get on it then it's still fine. Many LSDs will allow the wheels to turn when you have the back end in the air and try to tighten the lug nuts.
Reply 0
Mar 25, 2014 | 05:48 PM
Re: Wheels turn?
The car hasn't run in ten years so that what makes me mad how something could go wrong just sitting I talked to Moser this morning an said a lsd both wheels turn in the same direction an open dif. one wheel goes one way an the other wheel goes the other way. that is what mine is doing also Strange Eng. they said the same thing it is suppose to do that. who do you believe. any input guys need help! Thanks
Reply 0
Mar 25, 2014 | 05:51 PM
Re: Wheels turn?
If the Auburn is worn out then the wheels will turn in opposite directions. If it's still tight then they will turn in the same direction. This is with the transmission in neutral. With the transmission in park you can turn the wheel hard enough to make almost any LSD turn the wheels in opposite directions.
Reply 0
Subscribe
