9 bolt pinion bearing
Old Mar 31, 2014 | 11:22 AM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Bought me a used set of 9 bolt 3.45's .The gears look identical to the 3.27's i'm replacing them with, with the exception of the size difference of the inner pinion bearing. The 3.27 bearing is huge compared to the other 1. Any comment Big gear head?
Old Mar 31, 2014 | 11:53 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 9 bolt pinion bearing
Don't know if it's ratio or year dependent but there are two sizes of bearing. I ran into that and had to pull the bearing off the pinion and replace to match the carrier housing size.
Old Mar 31, 2014 | 11:56 AM
big gear head's Avatar
I don't have a lot of experience with the 9 bolt, but I know that the bearing size wouldn't change with the gear ratio.
Old Mar 31, 2014 | 12:25 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Thanks, shocked to see the difference. The big bearing is 1 they use in the ford 9".
Old Mar 31, 2014 | 01:07 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I was a little shocked too when I tried to assemble it. Got the "other" bearing and fortunately have access to a shop press so getting the new bearing on the pinion was a breeze.
Old Mar 31, 2014 | 01:41 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Def. harder to get it off with no exposed lip, lotta grinding and chiseling
Old Mar 31, 2014 | 01:45 PM
9 bolt is the only rear end I ever had any problems getting the bearing off. I busted 3 new bearings on one gear installation.
Old Mar 31, 2014 | 01:46 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Yes. I sacrificed a wood chisel and went round the bearing until I had a gap big enough to get a bearing splitter/puller under. And had to buy extra longer bolts for the puller to get it started.
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
