Need a clutch that will handle 400ish hp
Old Apr 14, 2014 | 06:25 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
Just put some drag radials on and my stock clutch can't hang. The clutch kit was just installed about 3 or 4 months ago, so I don't even know if I should be shopping for an entire kit or just the clutch itself.
Any suggestions would be great!
Old Apr 14, 2014 | 07:37 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: Need a clutch that will handle 400ish hp
ram sells a good clutch set up or borg n beck has a good one as well
Old Apr 20, 2014 | 12:50 AM
Stebo's Avatar
Car: 1992 RS Camaro
Engine: 305 soon to be 383
Transmission: Richmond -6
Axle/Gears: 4:10 with Auburn locker
Centerforce has stood up to some pretty good abuse from me.
Old Apr 20, 2014 | 09:51 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
http://www.dialaclutch.com/performanceclutch2.htm
first read that.......then make a more informed decision...
The LuK Pro Gold is a very good unit.
Old Apr 21, 2014 | 07:40 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i second this...
i have a centerforce clutch with drag radials and 420 ft/lb of torque at the wheels. It never complains...
Old Apr 21, 2014 | 10:23 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have to call BS on that article, it's just hype for his own products.
Old Apr 21, 2014 | 05:49 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
It does kinda read that way.........
we did ge very good service out of a LuK Pro Gold unit in a low 11s Chevelle...........
They dont list one of those for a 3rd gen tho................Hays is always a good option too....
Old Apr 22, 2014 | 05:59 AM
Stebo's Avatar
Car: 1992 RS Camaro
Yep!
Old Apr 22, 2014 | 11:19 AM
Dyno Don's Avatar
For our cars, the only problem with clutch kits is they are all made for 305's.
Any regular catalog will only show a clutch that is 10.4 in diameter.
The setup you will want with a 350 or larger is the parts from McLeod.
They don't list it as such but here are the part #'s
Pressure plate #360-709 (summit #MCL 360-709
The disc is # 260-571 (MCL 260-571)
This is an 11" clutch that mounts to a 10 1/2" bolt pattern.
The way they do this is by using a disc that is 10.95 diameter and special bolts. (they come with it)
A bit pricey, but will take 5K launches with drag tires.
PS Jeg's has a better price.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
