T5 Shift problems rev grinds gears won't go in
Old Apr 15, 2014 | 07:27 AM
dthela's Avatar
Car: 1987 Z28 zz440
Engine: ZZ440
Transmission: 5spd
Axle/Gears: 4:11
87 Z28 with zz440 and T5. lost ability to find gears qiute suddenly. shifts to all gears when motor off. With motor running grinds reverse and have to search and force into forward gears even when on the move. Replaced upper cylinder due to finding seepage around boot ( whoever designed the tube with pin set-up??) why not threaded connections??? but anyway Clutch hydraulics are bled GOOD. WTH is going on? Performance clutch, was thinking of making up and adjustable rod for slave cylinder although rod moves plenty and clutch disengages. Could it be a shifter alignment/missing bushings on shifter rods??? Thanks!
jklein337
Sep 19, 2018 06:23 PM
86White_T/A305
Aug 17, 2015 12:16 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
