gear question
Old Apr 27, 2014 | 09:07 PM
blackd-out z28's Avatar
Car: 1985 pontiac firebird t-tops
Engine: 350 with 305 heads
Transmission: t-5
Axle/Gears: 4th gen rearend with 3.23 gears
gear question
i am kind of new here. i just picked up a 85 t/a. the kid told me it has a 4th gen 6 speed rearend with 3.23 gears. is there any way to verify this?
Old Apr 28, 2014 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: gear question
The fourthgen rear is wider by several inches. Drop the diff cover and take a peek at the gears. The following FAQ provides the ratio numbers.
JamesC
Old Apr 28, 2014 | 04:12 PM
Transmission: t-5
Re: gear question
that explains why it sticks out so much in the rear
Transmission: t-5
Re: gear question
and why the speedo is off
Old Apr 28, 2014 | 08:52 PM
JamesC's Avatar
Re: gear question
Here's the link I neglected to post above:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 29, 2014 | 07:08 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: gear question
Did you maintain the stock tire height? because changing that can throw the speedometer off too.
Old Apr 29, 2014 | 09:31 AM
Transmission: t-5
Re: gear question
thinks its lowered 2"
Old Apr 29, 2014 | 10:01 AM
big gear head's Avatar
Re: gear question
Not the car, the tires. If you change the diameter of the tires it will change the speedometer reading.
Old Apr 29, 2014 | 01:14 PM
Transmission: t-5
Re: gear question
its go 235/55/17 with a fourth gen rear with 3.23 gears
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
