b&m shift kit problems help
Old May 15, 2014 | 01:11 AM
89CamaroAndrew's Avatar
Car: 89 Camaro Rs
Axle/Gears: 3.45 9 bolt
i installed a shift kit on my car and im having a problem with the shift points. the engine revs high and it wont shift unless i let go of the gas.. does anyone know what the problem can be? i did try adjusting the tv cable but that didnt do anything.. can someone help thanks
Old May 15, 2014 | 01:33 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: b&m shift kit problems help
Did the shift kit install involve messing with the governor?
Which B&M shift kit did you install (P/N)?
Old May 15, 2014 | 01:37 AM
Car: 89 Camaro Rs
no and B&M Shift Improver Kits 70239 whats the difference with the other kit?
Old May 15, 2014 | 12:37 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Was the transmission shifting OK before you installed this kit? Confirm the TV cable is attached at the VB end.
Did you install this kit in an attempt to fix something else?
Old May 15, 2014 | 02:18 PM
Car: 89 Camaro Rs
Yes it was ok before the kit and I'm gonna let me car cool down a little and try to see if I can find the problem and hope I don't have to take it apart... It's 100 degrees in California
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
g.l.mos
Aug 22, 2015 12:02 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
