Rear Diff Info
Old Aug 20, 2014 | 08:15 PM
klferguson26's Avatar
Car: 1982 Z28
Transmission: Stock TH200
Rear Diff Info
I purchased an 82 Z28 from a kid that did some "upgrading". According to him, it has a posi with 3.73 gears that came out of a trans-am. I checked for tags on the diff but there are none...so all I have to go on is what he told me. He said it was "some metric something...there is a smaller metric and a bigger metric one, and its the bigger one" To my issue...what were metric differentials? Are they any good? What are other alternatives? Thanks for any help in advance.
Old Aug 20, 2014 | 08:37 PM
big gear head's Avatar
Re: Rear Diff Info
Don't know anything about metric stuff. The 7.5 rear end isn't metric. The early 7.5 had a smaller pinion bearing that was upgraded to a larger bearing sometime around '82.
Old Aug 20, 2014 | 09:41 PM
Re: Rear Diff Info
So when you took the cover off and LOOKED, BEFORE you bought it, what did you ACTUALLY see?
What you saw is what you got.
Old Aug 20, 2014 | 10:21 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Rear Diff Info
Never trust what some one says when they're trying to get your money. Like posted above, you will need to take the cover off and look at the ring gear and carrier. The gear ratio should be stamped on the ring gear. How many bolts on the rear end cover? 9 or 10
Old Aug 24, 2014 | 08:03 PM
Car: 1982 Z28
Re: Rear Diff Info
So does anyone have any info on metric rear ends offered in Trans Ams? Or other alternatives for a better platform for upgrading? 10 bolt vs 12 bolt vs 9"? I am new to the GM scene so any help is appreciated. Thanks.
Old Aug 24, 2014 | 08:21 PM
Re: Rear Diff Info
Don't know where you are getting this metric stuff from. The only thing metric on the GM 7.5 10 bolt is the wheel studs.
The 7.5 can hold up to some street abuse if you upgrade a few things. The '82 to '89 had 26 spline axles. You can upgrade them to the '90 to '92 28 spline axles if you also upgrade the differential to one with 28 splines. The Auburn differential that was used in them was junk. The Eaton Posi or Eaton Truetrac are both nice upgrades. The ring gear diameter was upgraded from 7 1/2 inches to 7 5/8 inches around '86 and as far as I know all after market gears are the larger 7 5/8.
Old Aug 24, 2014 | 08:45 PM
skinny z's Avatar
Re: Rear Diff Info
Originally Posted by red rock
... How many bolts on the rear end cover? 9 or 10
Forget the metric handle for a minute. How many bolts in the cover? That'll give us a clue as to what you have and what you might be able to do to it.
Old Aug 25, 2014 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Diff Info
If the rear is a 10-bolt, the following FAQ may prove useful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Aug 26, 2014 | 09:14 PM
Car: 1982 Z28
Re: Rear Diff Info
The metric stuff is simply what I was told. I did find that thread JamesC, thank you very much. When I get a chance I will count the bolts. Any more insight and info is appreciated.
Old Aug 29, 2014 | 07:37 PM
Car: 1982 Z28
Re: Rear Diff Info
there are 10 bolts on the rear cover...trying to upload a picture but phone/computer are arguing....
Old Aug 29, 2014 | 10:05 PM
Re: Rear Diff Info
10 bolts means you have the 7.5 rear end. The '82 will have 26 spline axles.
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
E Rod
Aug 28, 2015 05:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
