L98/700R4 to T56 swap-HELP brake clutch pedal problems
Old Aug 21, 2014 | 06:10 PM
MrMac98's Avatar
1990 trans am L98 700R4 to T56
i have
4th gen pedals w gas pedal removed
1995 T56 w bellhousing etc. new clutch/flywheel/PP.
New 4th gen Hydrlics.
when i test mounted the new pedals with everything hooked up-
there is a radical difference in resting heights for the clutch and brake.
like 3-4" brake is very low. clutch pedal seems about right.
i think they should be even(or close)
i have read alot of threads on T56 swaps
but i see no mentions of pedal height differences...help....please.....thanks
Old Aug 21, 2014 | 10:13 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: L98/700R4 to T56 swap-HELP brake clutch pedal problems
If you think it will make the brake pedal higher, buzz your old one narrower and install it.
They make adjustable rod master cylinders (Ram, a stock-type IIRC; Tick and McLeod other versions)
1992 Trans Am
May 10, 2023 07:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
hokis
Aug 9, 2015 03:57 PM
