All 700r4's the same?
Old Sep 1, 2014 | 01:13 PM
modocwex's Avatar
i know that there are stock and HD mods. but i am looking to buy a new tranny and I see 700r4's for 4x4 and 2wd vehicles. some come with transfer cases. i am just wondering if any 700r4 will fit in my 89 camaro or if i need to find one that was in a 2wd vehicle?
Old Sep 1, 2014 | 07:33 PM
morgsie's Avatar
Re: All 700r4's the same?
F-bodies have a specific valve body and governor. This is what determines WOT and part throttle shift points.
Old Sep 1, 2014 | 08:52 PM
jokerZ71's Avatar
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
You will have to use a 700R4 from a V8 2wd vehicle.A V6 will have different valvebody calibration & governor setup,but,can work.A 4x4 trans will have to be torn completely down to install the correct tail shaft.
Old Sep 1, 2014 | 08:56 PM
OrangeBird's Avatar
Car: 1989 Firebird
The easy answer is , NO ! , They aren't all the same ....
That being said , there are some that are more adaptable than others . Look at the 6 cyl VS the 8 cyl , different bellhousing bolt patterns even though the rest of it looks the same from the outside (including the torque arm mount that is specific to our third gen) . No other 700R4 is going to have that tailshaft housing with the torque arm mount other than a third gen , but the housing can be dealt with too if you search this transmission forum a bit .
Old Sep 1, 2014 | 09:23 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Mine was taken from a 4x4 truck because I wanted the later version.
(The tail and other parts were swapped over.)
https://www.thirdgen.org/replace-700...c-transmission
Old Sep 1, 2014 | 10:32 PM
modocwex's Avatar
Thank you very much. I really appreciate your responses. Very helpful. A guy said he could put a 700r4 in from an 89 firebird. he isn't sure how many miles it has. does that sound extremely risky? i don't have the funds to buy a heavy duty tranny at this time. I plan on doing it in the near future, 1-2 years.
Old Sep 2, 2014 | 08:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
As long as the engine in the '89 Firebird and the engine in your car are both either a V6 or a V8, the transmission will swap in. If one is a V6 and the other a V8, nope, won't bolt up to the engine.
RBob.
Old Sep 2, 2014 | 02:26 PM
morgsie's Avatar
There are multiple v8 calibrations most of which have pretty lame shift points. The F-body has 5000-5500 rpm wot shift points and complementing part throttle shift points. Changing the governor weights in a run of the mill v8 700 usually give you less than desirable part throttle shifts. I have a spare F-body valve body if anyone is interested.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
