rearend rebuild
Old Sep 9, 2014 | 11:52 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
rearend rebuild
Where can I get a complete rebuild kit for my 9 bolt 3.27 rear? I have been looking around and so far all I have seen is just the rung and the pinion. Or does somebody have links to all the parts I need and where I can get them?
Old Sep 9, 2014 | 12:52 PM
big gear head's Avatar
Re: rearend rebuild
Randy's Ring & Pinion and 9bolt.com have parts.
Old Sep 9, 2014 | 01:08 PM
Re: rearend rebuild
But what all would I need? I'm not going to be rebuilding it myself but I'm trying to get all the parts for it.
Also my car is currently driving it just has a lot of backlash when putting it in gear and if I floor it you can feel it thinking around under the car. Would this necessitate a full rebuild or could it just be something else that needs replacing?
Old Sep 9, 2014 | 04:50 PM
Re: rearend rebuild
The Borg Warner differential in that rear end is the cone type. As they wear they get more slop in them. They can be reconditioned. There are threads on here that cover this and I'd recommend doing it.
A good installation kit will have all of the bearings except the axle bearings. It will also have shims, bolts, pinion seal, pinion nut and any other small parts needed for the job. You can get the axle bearings local or order them with the kit. I don't know how much stuff you need to fix the problems you have. I'm guessing that the gears are still good.
Old Sep 9, 2014 | 07:35 PM
Re: rearend rebuild
So its all a matter of tearing into it then huh?
Old Sep 9, 2014 | 07:45 PM
Re: rearend rebuild
I would recommend checking the backlash and contact pattern before tearing it down. Take pictures of the contact pattern and save them for the assembly so you have an idea of what to shoot for. You need to remove the axles before checking the backlash.
If you are going to install new gears then none of this matters.
Old Sep 9, 2014 | 08:40 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: rearend rebuild
Here is one good write up, https://www.thirdgen.org/forums/faq-...now-about.html There is a good blog with pictures, but you can't read the steps do to the background. http://mpikas.blogspot.com/2008/03/r...rner-cone.html
Old Mar 8, 2015 | 06:41 PM
87camaroz28.'s Avatar
Car: 1987 Iroc Z28
Engine: 350 tuned port injection
Transmission: 700r4, shift kit, b&e shifter
Re: rearend rebuild
First time posting, figured id make a account to join the conversations, but i do have a question
I just got a Borg warner 9 bolt posi rear, i want to find out the gearing and im told the p/n tells you all you need to know, well i found a site to look it up, and the p/n wasnt on it, some where close, but no cigar. Anyone have a site i can look it up at or any onfo
P/n 10046603
Ratio 3·45 sern
Old Mar 8, 2015 | 07:20 PM
Re: rearend rebuild
The part # you posted if memory serves, is the casting # of the housing. Not related to ratio in any way.
Not sure what you're asking about "gearing". If your gears have a 3.45 ratio, as you posted, then your "gearing" is .... 3.45. Whatever you saw when you took the cover off and inspected it before you bought it, that's what it is.
Old Mar 8, 2015 | 10:46 PM
red rock's Avatar
Car: 1987 iroc
Re: rearend rebuild
The 9 bolt rear was made in Australia for GM's third gen cars. The gear ratio IS the gears in the rear. The part number tells you nothing other than thats the part number for the housing.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
