gears 3.45 or lower??
Old Nov 9, 2014 | 10:58 AM
macneilbibi's Avatar
Car: 1988 Pontiac Firebird Formula WS6
Axle/Gears: Borg Warner 9 bolt 3.45 gear
so my question is does my car have 3.45's or does it have lower gears in the rear end
at 60mph i am reving about 2100 rpm in 5th
my buddy (vett guy) says that it reving to high to have 3.45's
car is coded to be 88 formula 305 tpi, t5, 9 bolt with 3.45's
maybe somebody changed out gear in the past
i have found other sleeper modification before
just wondering
Old Nov 9, 2014 | 11:11 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: gears 3.45 or lower??
Sounds about right to me. Driving the car at 70 mph in 4th gear (manual) or 3rd gear (auto), the RPM's will tell you your axle ratio.
Old Nov 9, 2014 | 12:39 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
"If you tach is accurate"
"If you have a .73 5th"
"If your speedo is accurate"
"If you have 25.7" tires"
You probably have 3.7 gears. 64 miles an hour would be 3.4.
Old Nov 10, 2014 | 06:32 AM
^^^ This ^^^
Since they usually fail by reading high, they make all kinds of people think they have gears other than what they actually do. (higher ratio # than reality)
If what gear you have actually matters to you in some way, LOOK AT IT. All of those "calculations", "spin the {fill in the blank} and count", and all that, is nothing but a bunch of GUESSES, which are hardly ever right. I would go so far as to say NEVER, but it's possible that ONCE, sometime somewhere someone somehow accidentally got the right # from some one of them somehow, although I don't think I've ever seen it happen, personally.
Changed your rear end fluid lately? I thought not. Go do that. While you're catching up on the "deferred maintenance" (politically correct term that means "neglect"), make a point of ACTUALLY LOOKING at the gears. Count the teeth. There is NO WAY for there to be any uncertainty in that. And since your next post is likely to be something about "posi", make a point of looking at that too; once again, all the "spin this and look at that" crap usually is WRONG, most usually in the direction of falsely identifying an open as a posi. Don't fall for it, go straight to the source, and avoid all the guessing.
Old Nov 10, 2014 | 07:33 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Start with that !! If the Tach reading is accurate,...... Your T5 tranny has a 1:1 4th gear. Get the car to 70MPH in 4th gear and note the RPM. RMP @ 70MPH in (T5) 4th = Rear End ratio.
Old Nov 10, 2014 | 10:42 AM
RamIt's Avatar
Car: 1984 z28
I don't think that is very accurate with stockish height tires.
My car spins under 3500 rpm with 3.73 gears in 4th.
Old Nov 10, 2014 | 09:30 PM
John in RI's Avatar
It is;
With an ACCURATE TACH,....... If the car is an AUTO then put it into 3rd (1:1) & run it up to 70 MPH and note the Tach. RMP @ 70MPH (700R4) in 3rd = Rear End ratio.
Old Nov 10, 2014 | 10:17 PM
RamIt's Avatar
Car: 1984 z28
It is;
Eh. Sorry. I was comparing my t5 in 4th. Must be a fair amount of slip in the auto?
Old Dec 7, 2014 | 06:05 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Engine RPM calculator - http://www.csgnetwork.com/multirpmcalc.html
Says 3.45 gears at 60MPH in a 5-Speed trans puts it at 2,174 RPMs with an .80 5th gear
Here's the chart that shows the gears of the T5 - http://www.moderndriveline.com/Techn.../tremec_t5.htm
Bubbajones_ya
Aug 28, 2015 02:17 AM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
