a 10 bolt rear end stock on 86 camaro Z28?
I recently bought a 1986 Z28 and want to know what is the stock rear end, I recently counted 10 bolts on the differential and wanted to know if it was stock or aftermarket. Its the LG4 model. I planned on getting rear end rebuilt and adding 3:73 gears anyway. Thanks in advance
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Re: a 10 bolt rear end stock on 86 camaro Z28?
I don't believe it was stock, when I went searching to buy a 10 bolt, I had to get one off a 91-92 z28, but I could be wrong!
3.23 came stock in mine, and if you were going to rebuild it anyway sounds good to me!
Starting in '82 GM used the 7.5 inch 10 bolt rear end in all F body cars. Around '85 or '86 they started using the Borg Warner 9 bolt in the high performance models, but the rest continued to use the 7.5 10 bolt. The 9 bolt was discontinued in '89 and all F body cars got the 7.5 inch 10 bolt (upgraded to 7.6 in '86) until '02.
Car: 1988 Camaro
https://www.thirdgen.org/1986-chevy-camaro
In '86 the Z28 got the 10 bolt, the Iroc got the 9 bolt.
The '86 Z28 had 2.73, 3.23 and 3.73 gear options along with open and posi.
If your car is an auto trans it will be a 2.72 gear, if man. trans then a 3.23, and could have option of posi 3.73
Car: '87 Trans Am
Engine: 5.0L-V8
Wow, great information to know.
I got my rear end out of a 92 Z28 5-speed does that mean it's either 3.23 or 3.73? The guy said he thinks it was a 3.23 but I haven't got it pulled apart yet.
Car: 89 Firebird
Engine: 355 TBI
If my memory is correct you may have a 3.42 gear I think it was an option after the 3.45 Borg Warner rear was discontinued.
Car: 1988 Camaro
https://www.thirdgen.org/1992-chevy-camaro
Every year seemed to be different
'92 Z28 had options of 2.73, 3.08, 3.23, 3.42
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
The '86 Z28 LB9 A/T was 2.73:1 or 3.23:1.
'86 Z28 LG4 A/T was 2.73:1 only.
'86 Z28 LG4 T5 was 3.23:1 only.
'86 Z28 L69 T5 was Players' Cup only, so you can't have one, but was 3.70:1 only.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
