clutch pedal options for t56 swap?
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
I wound up with 3 different clutch pedal setups for my t56 swap. I have a mechanical linkage pedal for 82-84, a set from an 85, and also a set from an 02 v6 with just the master. My 93 t56 came with the master and slave and appears in working order. I know the manual pedals won't work, so which of the other two will? I keep seeing/hearing about using a cavalier slave cylinder but I'm not finding much info
Re: clutch pedal options for t56 swap?
Either will.
The Cavalier part is related to using 3rd gen pedal sets. Just use a stock T-56 hydraulic setup if you use the 4th gen set.
The 4th gen is probably the best one to use.
Car: 86 Z28
Engine: 385 HSR
i wound up using the 4th gen set. i liked how the clutch master bracket was one piece, and that the upper mount was removable. the t56 master rod is longer than the t5 it came with, so i may need to shorten it at some point
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
rsrmoore
Aug 7, 2015 08:44 PM
