Rear end not sitting correctly
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Rear end not sitting correctly
If it's the same as mine where the panhard bar attaches to the body on the passenger side, a bent bar would probably pull it towards the passenger side but it'd be good to check anyway. Could be the ride height's a bit lower than it used to be due to sagging springs etc which would push it towards the driver side a tad. It might be that being a little off-center is normal for these cars, since I've yet to see a stock one that is centered, but I don't have any evidence that that's always the case. Looks like a great buy
Engine: 5.7L TPI
If it's stock then it can't be adjusted. I just went with the stock on mine, but if you want to be able to center the rear you might want to go with an adjustable one. Some people who keep the stock bar like to have a plate welded to the bottom so that it's fully boxed in which gives it a bit more rigidity, but if it's just a daily driver the stock should hold up fine.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks normal to me. I think every third gen looks like that. It's just a lot more noticeable when you install wider tires/rims.
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Pick your poison.
http://www.foundersperformance.com/c.../Panhard-Rods/
Engine: 4++,350 & 305 CIs
That is 100% normal, some are better, some are worse.
Buy a adjustable panhardbar. And a stock hood.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
