Clutch won't disengage, then starts working
Old Feb 23, 2015 | 10:07 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I had this problem a few months ago. After my car sat for a few days I get in to start it and the clutch won't disengage. The clutch pedal felt normal. I pumped it about 10 times and it was fine. I changed the slave cylinder after that and didn't have any more problems.
A couple months later, same thing. I let the car idle for a couple minutes and pumped the clutch pedal and it started working. The clutch will then work until I shut the car off and let it sit for awhile.
Should I just blindly change the master cylinder? The fluid is also pretty brown, wondering if it is clogging up the slave when it sits? I have an LT1 T56 with LT1 master/slave.
Old Feb 26, 2015 | 01:55 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Clutch won't disengage, then starts working
Sounds like you have a leak somewhere.
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
hokis
Aug 9, 2015 03:57 PM
rsrmoore
Aug 7, 2015 08:44 PM
