8.8 swap driveshaft
Old Mar 8, 2015 | 07:48 PM
hunterhitt's Avatar
8.8 swap driveshaft
Swapping to an 8.8 this week. Car has th350. Do I need the strange engineering yoke instead of the flat ford yoke
Old Mar 8, 2015 | 08:10 PM
big gear head's Avatar
Re: 8.8 swap driveshaft
You can use the Ford flange if you get the end off of a Ford drive shaft that fits it. Then you can use an adapter U joint to mate the Ford end to your drive shaft.
Old Mar 8, 2015 | 08:12 PM
hunterhitt's Avatar
Will I have to shorten of lengthen my shaft
Old Mar 8, 2015 | 08:24 PM
Can't say. You will have to test fit it and see.
Irocguy01
Sep 28, 2015 02:03 PM
theshackle
Aug 23, 2015 03:49 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
