Where to get the correct VSS for a WC T5 ???
Old Mar 14, 2015 | 11:32 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I'm confused. My 91 T5 has a VSS that looks like this:
The only ones I see in the parts stores and online for my year look like this. Which is clearly not going to work. Any help fellas?
Old Mar 14, 2015 | 06:25 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Where to get the correct VSS for a WC T5 ???
The bottom one is for an auto
I might have the one you need, i'll check, they are really rare.
Old Mar 15, 2015 | 11:49 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Thanks Don. Lemme know. I see a couple vendors out there have some old stock ones that float around $175-$225. That's a little steep though.
Old Mar 15, 2015 | 11:51 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
On the same subject. My speedo and tach are working fine but the car is throwing the VSS code every time I drive it. It also smells like it's running a bit rich. Does the VSS work along side the other sensors that adjust fuel/air?
Old Mar 21, 2015 | 02:39 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Well I found a replacement (used) and I'm still throwing the code 24. Is there a test procedure that anyone knows about or should I just assume that my ECM/ECU is the problem since it's a 91 T5 Speed Density car???
Old Mar 22, 2015 | 12:26 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'm guessing the speedometer on the dash works?
You'll need to hook up a scan tool and see if the ECM is seeing the correct speed as well.
Old Mar 22, 2015 | 12:33 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Speedo works. It even seems accurate when compared to my GPS. Like I mentioned earlier. I've tried two VSS sensors and they both produce the same result (code 24). What scan tool would you recommend?
Old Mar 22, 2015 | 12:55 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I'd also add that I had my prom flashed to tune out the EGR and AIR components. I mailed it out to harris performance and he did the tune based on my car. I just had the engine rebuilt prior to this, so I really can't pinpoint if it happened after the new prom tune. I just knew that when I had it all apart that I didnt want to bother with all of the emissions crap when putting it all back together. It it possible that could have something to do with my code 24?
Old Mar 22, 2015 | 01:08 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Another thought. Does anybody know which/what color wires at the ecm are for the VSS. I was thinking I could bypass the harness and splice/wire the VSS directly into the ECM to rule out a short. Just do that and take a drive with the wire(s) run from under the car through the drivers door and into the ECM. Thoughts?
Old Jun 2, 2015 | 09:06 PM
southbaysd's Avatar
Car: 1990 Firebird Formula
Engine: 5.0 TPI
Do you still have one? I am trying to locate one
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Vintageracer
Sep 24, 2017 12:34 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
Bigold4x4
Sep 28, 2015 05:21 PM
