What clutch kits do you recommend for the T5?
Old Apr 9, 2015 | 01:46 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Just wondering what a good clutch and pressure plate kit would be for a T5 and mild 350 combo.
Old Apr 10, 2015 | 09:56 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: What clutch kits do you recommend for the T5?
McCleod...
they sell one that is almost 11", almost half inch bigger than stock, but fits and works... Im using it and a few other members. Do a search, I posted part numbers In another thread.
Old Apr 10, 2015 | 10:36 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally Posted by luvofjah
McLeod...
Here are the #'s for McLeod
360709 Plate
260571 Disc
Old Apr 10, 2015 | 10:59 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks for the info
Old Apr 11, 2015 | 11:29 AM
Granny's Avatar
360709 Plate
260571 Disc
That 2900 plate load will be a T5 killer without some slip/engagement delay to smooth things out. You could use a lighter PP load to get a little slip when you dump the clutch, or you could add a little engagement delay with a device like the ClutchTamer
Old Apr 11, 2015 | 12:18 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I had a look at Those McLeods, they seem a lot more clutch than I would ever need, and quite expensive. It'll never see a track or racing. I've since discovered the Ram Stage 1. I think that may be more inline for my application. I'd rather a bit of forgiveness in that clutch.
Old Apr 11, 2015 | 12:43 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have been happy with my see spec stage 1
Old Apr 11, 2015 | 01:13 PM
Dyno Don's Avatar
Maybe it's the 360710
Old Apr 11, 2015 | 05:56 PM
luvofjah's Avatar
For the record, my McLeod is very smooth... Street Car so far... Not been to the strip yet
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
rsrmoore
Aug 7, 2015 08:44 PM
