U joint clips won't fit
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Engine: 4++,350 & 305 CIs
Re: U joint clips won't fit
If that's the rearend yoke, you don't use the clips back there. The yoke has tabs on the outside that locates the caps correctly and it looks like you have bent the retaining strap or I hope its not tight on the other side.
Car: `86 SS / `87 SS
3R / S-44 joints use an inside clip like that.
1310 which were used on f-bodies too, use an outside clip.
If you google 3R 1350 1310 1330 measurements and measure stuff, you may figure out you need a conversion u-joint with one axis 3R sizes and the other axis 1310 sized.
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Straps are tight and are not bent. The yoke does not have the tabs, neither does the old rear....
I ordered both a u joint for 87 and 02 both were the same...
Car: 88 Camaro
Engine: L98 350
Not unusual when removing joints to bend the yoke a bit, then those clips won't quite go in. Why I like to cut out the joints and then push out the cups one at a time. Just have to spread the ears enough to get the clip in, or grind down the clips a little. And hope the joint is centered enough that it doesn't vibrate.
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Bend the yoke??? Wtf?
This is the yoke, not the driveshaft part...
Man what happened to the tech quality of this site...
The Yokes can and do bend a little bit when pressing U-joints in/out. Happens mostly to the DS and Trans Yoke and not so much with the rearend yoke.
Anyway, Odd you don' t have the tabs.
If all this is, is at the bolt-on straps, then use a C-clamp and acoupla sockets to compress the U-joint all the way together. Install one cap with the bolts slightly loose, compress, install the other cap, tighten.
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
I am having the same issue... Not sure WTF is up but the inside of the pinion gear yoke measures exactly 2.500 across the inside flats. The U-joint I have ( Moog # 234 ) is 2.557 from c clip to c clip. Tried to force it on the yoke and the land on on of the bearings broke off. Just as in the photo that Camarothatcould posted the yoke is smaller than the distance that the clips are. The yoke does NOT have tabs on the OD to hold the bearing cups. Tries centering the shaft and tightening the straps worked ok till I hit about 80 MPH then shaft moved off center and BIG vibration problem. I have not found a u-joint that is 2.500 across the clips. At this point only solution I can find is to grind off .30 the clips to make them thinner to fit. NOT a fix that I am very comfortable with but I have no other solutions available unless someone have something constructive to suggest...
Dave
Dave
Gave up and ground .30 off the clips so they are .70 thick. Shaft in and. Vibration is gone...
Car: 88 Camaro
Engine: L98 350
I've had to do that before too, but not to that extent.
Curious, where was that U-joint made? I've had lots of troubles with Chinese made joints, metric may be close, not exact I'm thinking?
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
This can't be this hard of an issue... Jesus. ... this swap has been done a million times...
Not sure where they were made, but 2 were ac delco
Car: 84 Z28
Engine: 383 Stroker
Ac delco =china.
Precision = USA and is usually what I run. (grease-able obviously.)
TRW/Federal Mogul= USA and is a good product.
DANA= USA hands down the best. May have to cross some numbers but can be done.
I noticed this is a few weeks old. Did you get it?
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Nope.. still driving it, I dont think it's going anywhere but I have a 1000 mile tour coming up and I'd like to get it fixed
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
what we usually do is when the joint is out we file down the inside where the clip rides to get rid of the grease and debris or just file the the snap ring a hair to fit but we usually dont do that
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Was at napa for 45 mins looking through theor book and taking and measuring joints off the shelf, nothing... I dropped the original joint off at a driveline shop. The factory 87 joint fits perfect in the 00 rear yoke
