Clutch problem
Clutch problem
I have a 92 camaro rs. The problem is when I press my clutch in, it seems as though the car is still in gear. When the car is cold, shifting is easy and without a problem but as it heats up, shifting becomes near impossible. Please help.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Clutch problem
first thing check fluid level . if your problem just started and all was well before . well , you may have a leak . any noise , binding , etc. ? a little more info. needed . first check fluid level in clutch reservoir . good luck ...
Re: Clutch problem
Probably a bad pilot bushing/bearing. (whichever happens to be in it)
Leave the hydraulics alone. 99.999% of the time, they either work, or they don't... not much in-between.
Since you'll have to have the whole thing apart, might as well put in a new clutch while you're at it.
theshackle
Aug 31, 2015 10:47 AM
db057
Aug 11, 2015 10:11 PM
rsrmoore
Aug 7, 2015 08:44 PM
