Intermitent Lockup Problem.
Old 11-28-2015, 01:40 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
I've got an issue with my torque converter locking up that I'm trying to diagnose. I've got a 1988 IROC with the L98 and 700r4 from bowtie overdrives with one of their 2,400rpm stall converters.
I've had this setup in my car for 3 years and lockup was working fine until about a month ago. After starting the car when it's cold lock up works fine until about 10-15min then it won't lock up at all. Could it be a loose electrical connection or something in the converter itself? I'm not getting any check engine lights either.
Old 11-29-2015, 12:10 PM
Beeman's Avatar
Re: Intermitent Lockup Problem.
While driving take your left foot and pull up on the brake pedal. Lockup kicks off when brakes are applied, sometimes switches go bad.
Old 11-29-2015, 02:00 PM
yaj15's Avatar
Car: 1988 IROC-Z
Thanks I'll check that out.
Old 11-30-2015, 03:04 PM
keykey's Avatar
Car: 1988 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH700R4
Axle/Gears: 3.27 9-bolt w/ Torsen LSD
There is a terminal in the diagnostic connector that locks the TCC if you ground it. I have a problem with my TCC not locking all the time, but it always does when i ground the TCC terminal in the ALDL, so that's how i found out it was a ecu problem.
Old 11-30-2015, 03:11 PM
yaj15's Avatar
Car: 1988 IROC-Z
I worked on my car yesterday. The throttle position sensor isn't working properly because the metal tab that rides on the throttle blade was broken. Computer has no idea if the throttle is open or closed so that's part of the problem. I ordered another TPS so hopefully I'll be able to eliminate that variable as part of the problem.
I'll check out that TCC diagnostic and see if that works out. I've had better luck with AC/Delco computers in the past. I'm using an ECU from NAPA now and that may be part of the problem too.
Piston454
12-03-2015 10:27 AM
stealthram92z
11-30-2015 10:11 PM
Joshbgolden
11-28-2015 11:52 PM
reborn92rs
Brakes
11-23-2015 01:02 AM
michael pippin
11-21-2015 09:06 PM
Quick Reply: Intermitent Lockup Problem.
