Clunk when accelerating
Old Feb 27, 2016 | 11:33 AM
kleetis's Avatar
Car: 88 Camaro z28
Hey I have a question that i need help figuring out. I have a 88 camaro that has a single clunk when it accelerates kinda fast from a stop, it does not happen when it neutral or park but it have when revving and holding the brakes. could this be a bad torque arm? Please help.
Old Feb 27, 2016 | 11:54 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Clunk when accelerating
Classic sign of a bad transmission mount. Torque arm doesn't really "go bad", it would either bend or maybe break. Never heard of that happening though.
Old Feb 27, 2016 | 11:57 AM
kleetis's Avatar
Car: 88 Camaro z28
Thank you.
Old Feb 27, 2016 | 12:22 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
or bad torque arm mount. may as well check while your under there.
Old Feb 27, 2016 | 04:21 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Universal
Old Feb 27, 2016 | 07:11 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
This. So much this. I've torn up 3 trans mounts so far in the 3 years I've owned the car.
Old Mar 3, 2016 | 08:18 PM
I cannot TELL YOU how many trans mounts I have tore up in my car. I tore one up one time THE VERY FIRST TIME I took off after putting it in and backing down the driveway.
That whole part of our cars is a giant engineering .... erectile dysfunction.
It quit after I put in a torque arm with a sensible design, that wasn't constantly trying to tear up the trans mount.
Old Mar 4, 2016 | 01:12 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Normally you will hear a broken/tore transmission mount "clunk" (feels like it wants to come through the floor between the front seats), when you shift from "park" into "gear" from a stop.
The way to see if the transmission mount is bad is to place a decent size block of wood under the transmission oil pan so the jack won't punch through it an jack it up a "little" bit.
You are looking to see if the rubber part of the mount has torn away from the metal mounting plate that it was attached to.
If you just look at it without lifting it , it will look fine.
It was a pain to find the Polyurethane Transmission Mount that would work but I finally did.
Energy Suspension Mount # 3.1108G with out using the pre-load plate.
No more torn trans. mounts for me.
Old Mar 4, 2016 | 09:06 AM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
Check the bushing. And definitely get the poly when you replace it. You won't be disappointed!
Old Mar 8, 2016 | 05:42 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i put a poly mount in and haven't looked back and that was 20 years ago
Old Mar 8, 2016 | 08:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Not all members are happy with the poly mount. You might consider checking the following link for info before throwing down your cash.
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
graysmoke
Convertibles
17
Aug 19, 2016 12:03 PM
Ohlmin
Jul 13, 2016 09:30 PM
1992rs/ss
19
May 18, 2016 03:34 PM
LC2 TECH
16
Apr 9, 2016 05:12 PM
Abubaca
Feb 23, 2016 09:23 AM
