700r4.Differential Grinding in Reverse
Old Mar 2, 2016 | 02:11 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Having this problem on my v6 3.1 automatic. Was driving like normal and pull into a driveway , put it in reverse and as i hit the gas it just revved up and jumped back and I could hear the differential grinding . I had to rev it up high to reverse and was jerking back and differential was grinding bad. But drove fine in drive. Any suggestions help?. Seems like it's my rear.
Old Mar 2, 2016 | 07:16 AM
big gear head's Avatar
Re: 700r4.Differential Grinding in Reverse
Nope, it's your transmission. A rear end can not slip. It either works or it doesn't.
Old Mar 2, 2016 | 08:36 AM
Pinion nut is loose, and pinion is getting sucked into the housing when in reverse (in drive it tends to push itself out) and rubbing on the outside of the carrier.
Old Mar 2, 2016 | 12:51 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
So is it my trans or differential....? I have a 84 z28 10 bolt rear... Would that swap into a 92 rs v6???I could swap in if its the differential or is it in easy fix?
Old Mar 2, 2016 | 02:22 PM
Get under the car and see if you can move the yoke on the rear end up and down. If it doesn't move then take the transmission to a rebuild shop and get it fixed.
Old Mar 2, 2016 | 02:24 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Just checked it and it doesn't move. So It's the trans then ��
Old Mar 2, 2016 | 02:31 PM
Yea, take it to a transmission shop and have them verify it.
Old Mar 2, 2016 | 07:10 PM
Pop the rear end cover off and look, before submitting your checkbook to THOSE people. $15 of fluid vs $1500 of transmission... whaddya got to loooooze?
Old Mar 3, 2016 | 01:38 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
You were right sofaking I have been ignoring my rearend . So I drained and filled with some fresh valvoline and problem went away with a few hours of driving. Hope it doesnt come back. For now I will take it easy on the 3.1
Old Mar 3, 2016 | 07:30 AM
Were there pinion marks around the outside of the carrier?
Out of curiosity, what gears did it turn out to have?
Old Mar 11, 2016 | 08:20 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
It had stock gears and I'm not sure what the carrier is but the inner smaller gears looked very worn. Well the problem came back again were I couldn't reverse so I checked the trans oil and it was overfilled and bubbling..... thing is when I did the oil change on trans I remember getting the oil level right at the hot mark . So I drained some oil and I had reverse again. I think maybe I need a fan on my trans cooler ha.
V6camaroman
May 9, 2004 02:19 PM
Chris89GTA
Jan 3, 2003 01:31 PM
Carbine
Jun 25, 2002 09:34 AM
vortech305
Mar 13, 2001 09:13 AM
ArnoldBraker
Jan 15, 2001 12:02 AM
