not another megashifter question...
Old Apr 3, 2016 | 06:42 PM
802maro's Avatar
Car: 91 Z-28
Engine: 350 carb
Transmission: built 700r4 megashifter
Axle/Gears: 4th gen 3.73s
so im getting a megashifter and have been researching the installation on the site. i have a few questions...part#80692
do i NEED a relay from radioshack? ive read that i do and read that i dont.
when i hook up the nss and backup lights... (im not sure if i will get directions with this or not) i know the purple wire from the starter goes to the nss. which other wire goes to the other male prong on the nss? and which wires should i be hooking up to the reverse lights? i read something about dark blue?
Am i going to have a problem with lockup by installing this shifter?(i could be getting issues confused as i am converting from tpi to carb, and it could be a problem with that swap) i remember reading about the lockup being controlled by an orange wire w black tracer.
the rest of the shifter installation i have researched lot nd shouldnt have nay issue installing. thanks for any and all help. new to this camaro and thirdgen.org
Old Apr 6, 2016 | 07:38 AM
802maro's Avatar
Car: 91 Z-28
Engine: 350 carb
Re: not another megashifter question...
Bump for any help, shifter comes in today and would love to hear the car run tonight! Just need help with which wires hook up to the nss and b/u lights
Old Apr 6, 2016 | 07:55 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Instructions come with the shifter if its new.
Old Apr 6, 2016 | 08:03 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The PDF used to be on their website, but I see it here as well:
http://www.carid.com/images/bm/trans...structions.pdf
Old Apr 8, 2016 | 04:32 PM
UKPROCHARGEDGTA's Avatar
Car: 1989 Trans Am GTA
Engine: Procharged 350tpi
Transmission: uprated 700R4
everything you need including instructions comes with the megashifter
fairly straightforward, fitted 2 to 3rd gens (mine and sons car)
Old Apr 9, 2016 | 12:01 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
if your going to a none lock up..its not needed.
if your keeping the lock up...do not cut your plug.. just use pin sets. and install the wires into you plug.. then do the install per B&M.
Old Apr 9, 2016 | 05:15 AM
802maro's Avatar
Car: 91 Z-28
Engine: 350 carb
Darn I wish I had got that message before I installed the shifter. I do need lockup as I have a "stock corvette converter" (which I believe is a lockup converter, please correct me if im wrong). Thats what my builder told me. From what I read, I thought my only option was to wire in a switch for lockup. Which ive done on my truck, and do like the function.
If I leave the trans without lock up... ive read that it will not phgsically hurt the trans and only cause fuel milage issues. Ive also read it burns out the 3-4 clutch packs. Can anyone who knows school me on that?
Black_TA
Mar 20, 2016 09:54 PM
mclenty0
Mar 18, 2016 09:11 AM
BeyondZ28_85
Mar 16, 2016 06:34 PM
marz1129
Mar 10, 2016 04:34 PM
ellefsonz
Mar 8, 2016 08:10 PM
