Pinion Failure and rebuild questions
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
The pinion gear failed on my stock 1984 disk rear.
I am planning on rebuilding it with a yukon duragrip, gears and master rebuild kit. I already have the TA performance cover even though it has a nice gouge in the inside now. I was not sure if I need thick gear but I am guessing not because the yukon duagrip says 3.23 and up. I am also considering going down to 3.42 so I don't have to max the engine in second to get over 60.
I was thinking about these parts, can anyone confirm they are the correct parts?
Yukon Master bearing kit YK GM7.5-B
https://www.yukongear.com/productdet...px?ProdID=1130
Yukon 3.42 regular gears YG GM7.5-342
https://www.yukongear.com/productdet...px?ProdID=1064
Yukon duragrip YDGGM7.5-3-26-SM
https://www.yukongear.com/productdet...px?ProdID=5304
Re: Pinion Failure and rebuild questions
Should do it.
You are correct, since that is a 3 series carrier, you need std gears, not the "special" thick ones for putting a 3 series ratio on a 2 series carrier.
Battle scars.
I am thinking about getting new axles and going 28 spline.
Are these the correct ones to upgrade? I have rear disks
https://www.summitracing.com/parts/s...t/model/camaro
Crush Sleeve eliminator
https://www.summitracing.com/parts/yga-55047
And 28 Spline duragrip
http://www.ebay.com/itm/1990-1999-GM...-/231443924580
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
waste of money... with anytning more them 300 hp..400hp and all the teeth come off the pinon.. axles.are not needed. as the pinon lets go before them..
this info comes from a stack of broken rings and pinons.and..hp.... FYI
Right but the bearing surfaces on one of mine is starting to pit and as a28 spline center costs the same as a 26 I may as well go 28 spline axles while I am replacing them
Yes, those look like the correct parts. I don't see where you posted the amount of power that you are making, or what you use the car for. The 7.5 might hold up pretty well for you, or it might just break again. It depends on how you are using it.
I plan on using the car on the street never anything wider than a 235 tire 1-4k miles a year and if it gets to the 1/4 mile track once in the next 5 years it will be a miracle.
The last pinion was the factory 3.73 and it finally died after 5 years behind this motor and whining the entire time with a powertrax locker. The death of it coincided with a rear U joint that failed.
I had my friend weld up the cover for me just because I could. There was a gouge and a deep scrape about 1/2 way through the cover on the big side. We hogged it out a little to make sure there were no cracks and then filled then I ground it down.
