Problems with 5th Gear
Old 08-23-2016, 11:22 PM
90SpeedRacer's Avatar
Car: 1991 Camaro Z28
I've got a 1990 Camaro RS with the 305 TBI motor and the stock transmission that came with it. For the last 6 months or so, I've been having problems when it comes to shifting into 5th gear. It will grind into 5th (even after matching revs), and occasionally pop right back out. Anyone have any possible solutions for my problem?
Old 08-24-2016, 08:05 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Problems with 5th Gear
You can check fluid level, shifter cup and all that good stuff but the real solution is to remove the trans, pop off the tail shaft and cover then replace the worn parts near 5th gear.
The good news is 5th gear is super easy to work on vs the rest of the transmission and dose not require any special tools beyond some punches and snap ring pliers.
MantyZ28
07-24-2018 07:47 AM
racing28x
Members Camaros
03-16-2017 02:55 PM
Mattkovitch
06-06-2016 09:35 AM
MantyZ28
04-11-2016 12:04 AM
'91CamaroRS
03-15-2016 03:12 PM
Quick Reply: Problems with 5th Gear
