flywheel/clutch
Old Sep 1, 2016 | 09:04 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
flywheel/clutch
I have a l98 motor and may put it in a 89rs with a t5. Right flywheel and clutch stuff. I believe the block was cast in 88. Valve covers are center type. Also I can get a 95 truck 350tbi complete for 200. Sons dady in law! He needs money and will pull it. Has a manual truck flywheel on it. Dose it got a be change to fit my t5
Old Sep 2, 2016 | 10:35 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: flywheel/clutch
Isn't this the tranny forum? Nobody ever put a 350 into a 5 speed car b4?
Old Sep 3, 2016 | 09:19 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: flywheel/clutch
the truck flywheel is likely the larger one which won't fit into the T5 without catastrophic metal removal
Old Sep 3, 2016 | 11:12 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: flywheel/clutch
L98 heads will flow better than TBI heads.
The 153 tooth flywheel will fit in the T5 bellhousing. The 168 tooth flywheel will not.
Old Sep 3, 2016 | 11:27 AM
Re: flywheel/clutch
Truck stuff won't fit.
Use the one off the 89 TBI motor.
Old Sep 3, 2016 | 10:07 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: flywheel/clutch
There was no motor in the 89 rs. It was a roller with its t5 tranny.no flywheel and no clutch or pressure plate. Inspection cover missing to.so I need one if you got an extra. What I'm not sure of is the truck motor able to have a smaller manual flywheel put on it and the motor run right? You know still stay balanced!
Old Sep 4, 2016 | 03:11 AM
naf's Avatar
naf
Re: flywheel/clutch
89 fbody flywheel will fit 95 truck motor
Old Sep 4, 2016 | 07:03 AM
Re: flywheel/clutch
Balance will not be a problem.
Just get the flywheel and clutch for the 89 car.
You'll find there are 2 flywheels available; one will be around 16 lbs (for TPI cars), one will be around 22 for TBI. You'll probably like the 16 lb one better.
Old Sep 4, 2016 | 07:27 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: flywheel/clutch
Thank guys.
hotrodhonda02
Apr 20, 2016 06:51 AM
Z28DJP1987
Aftermarket Product Review
May 3, 2001 11:10 PM
colinfinkle
Apr 5, 2001 04:13 PM
soulbounder
19
Mar 14, 2001 08:22 PM
84TransAm
Dec 2, 2000 07:09 AM
