4.10 gear set noisy - best brand?
Old Dec 8, 2016 | 06:36 AM
Buickstaged's Avatar
Car: 1984 firebird se
Axle/Gears: 373
I bought a 4.10 gear set for a 7.5 diff. I had the sets put in (all new bearings, diff rebuilt) The 4.10 gear set is very noisy - it is from Jegs (their own brand). This will not work - the installer (years of experience - works in a tranny/diff shop) says they are a b-grade. Should only be used on a truck - I am interested in the different levels or whom you have had good experience with. Motive, Richmond, Summit, etc. Any and all thoughts are appreciated - thx byron
Old Dec 8, 2016 | 06:51 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 4.10 gear set noisy - best brand?
Motive or us gear i have heard are alittle quieter but alot of it is in how you set them up
Old Dec 8, 2016 | 07:13 AM
big gear head's Avatar
If you want the best then get the AAM gears. They are the OEM supplier for GM. US Strange from Tom's Differentials or Quick Performance is also good. Yukon is a pretty good brand. Motive is hit or miss. Summit, Jeg's USA Standard, Richmond Excel and other bargain brands are usually going to cause problems, although I've had pretty good luck with some of the Excel gears.
Old Dec 8, 2016 | 07:46 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have never used AAM gears, never even thought of it. Thanks..
I sure don't recommend 4.10s in a 7.5 or the "bigger" 10bolt. even with street tires they can be a time bomb unless grandma is driving.
Old Dec 8, 2016 | 09:38 AM
If you do get AAM gears be sure that you set them up correctly. They will be 2 cut gears where most others are 5 cut gears. They do not set up the same way.
Old Dec 8, 2016 | 12:04 PM
Biledriver's Avatar
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Ttop350 is right, 4:10 pinion for that rear is about as big around as a silver dollar. I always use Richmond unless it's a stang and I'll use Ford racing. Always quiet. When I do one I take a pic of the pattern to show the customer I wasn't slacking. I would suspect they got it wrong if the gears you got aren't hardened racing gears, maybe get someone else to check out their work.
Old Dec 9, 2016 | 07:35 AM
Axle/Gears: 373
Guys, thanks for the replys. I spoke with Jegs - I did order a set of Richmonds - they are made in the USA. The Jegs guy didn't admit the issue with their 4.10s, however, he was pretty quite about it and said - Oh, send them back. Time will tell - I was concerned about the over rev with the 4.10s. I have a limiter that will be used on the motor - it went through the gears pretty quickly.. thanks again - your input is much appreciated - byron
Old Dec 9, 2016 | 08:11 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
if they are noisy. they are not set up right. that's the bottom line...and like posted.. not going to last with good power...pinon teeth with snap and crack at the roots...on that rear end size...
Old Dec 10, 2016 | 02:58 AM
project89's Avatar
i donno know about that , my turbo v6 car has 4:10's it with a spool , i run a 28x10.5 slick and launch that sucker with enough boost to go 1.4 60's , the only thing ive ever broken was axles and thats more due to street driving with a spool then the launches
motor makes over 400ftlbs of tq , its been threw years of abuse as well
but then again we all know ppl who grenade rears with bone stock motors including 305 and v6's so who the hell knows
Old Dec 10, 2016 | 06:40 AM
Axle/Gears: 373
Thanks to all, the car has 235/60/15 street tires - minimal grip. I do not anticipate it will be raced. I am concerned about the installer as a few have mentioned above. It goes back to him this week - he is also working on shift points in the 700r4 that he built. Will know later this coming week... I like the idea of taking a photo of the paint on the gears....thanks ... byron
Old Dec 10, 2016 | 10:56 AM
TTOP350's Avatar
Exactly! You just never know, had a friend do a rolling burnout on street tires with 373s and busted off 3 teeth.
Its just hit or miss
Old Dec 10, 2016 | 01:05 PM
with over 400 fpt at 1800 rpm they just fall apart...1.44 60 ft 28x12.5x15 ET Streets.
1st set zoom.. 2nd&3rd set Richmond.. as they had a life time warrenty..its a time bomb with that small of a ring gear..
there is a way.. to just forget about braking rearend parts....
Old Dec 10, 2016 | 03:38 PM
Biledriver's Avatar
Engine: 383 sbc
My wife broke 3 teeth off my pinion fooling around so I ordered a a moser 12 bolt. Told the it was street only but they put hardened gears in it and it was unbearably noisy. I rebuilt it with Richmond gears and it's great now.
Old Dec 11, 2016 | 06:53 AM
Axle/Gears: 373
Artic - that looks like a pretty serious rear end... thanks to all, I will give some feedback on the gears - thx byron
Old Dec 13, 2016 | 10:10 PM
got tired of breaking them itty bitty pinons on the 7.5 toys
got rid of another 20lbs by going to a aluminum housing..this yoke is getting swaped out for a billet yoke before getting installed..
