clutch that will hold up on dragstrip
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
looking for a clutch kit that will hold up at the weekly dragstrip test and tunes,stock one dont last long,stock 350 with t5 and its not a drag car just a daily driver with 3:08 posi,will run dot street slick tires 275/60/16.not loooking to break bank just tired oem part stores stuff
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: clutch that will hold up on dragstrip
Stock 350 out of what? Makes a huge difference
OEM reman for what car? is it a 150hp 350 or a 400hp 350? They came in just about every cr for 50+ years
Engine: 355 carb'd
Transmission: 5spd
low horse i'm sure,looking at maybe
MCL-75225 - McLeod Super StreetPro Clutch Kits or a
ZZZ-HP1675-1A - Zoom High Performance Clutch Kits
but review on kevlar zoom not favorable
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
McCleod makes one that is slightly bigger than the size they sell for 3rd gens / T 5's that fit, I have one and several other members do... I think it's rated to 500hp.... do a search here...
I had a Centerforce DF in my 427 Camaro that I beat on for many years with no problems at all. It's still a very good clutch. Just upgraded to a McLeod dual disc RXT.
Engine: 355 carb'd
Transmission: 5spd
since not gonna make it an auto,tire size and rear gear is about only option?
That tire is 29 inches tall. Put that together with a 3.08 gear and it's a wonder that you can get the car moving. I'd probably go to a 3.73 or 4.11 with a tire that tall, or go to a tire that is about 24 inches tall.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I broke my first "World class" T5 doing clutch drop burnouts with a 305TBI and street tires. Those transmissions break easy so I don't advise using any kind of drag tire, dot for street use or not. A T5 can live behind a decent engine but your 60ft times will always be poor and your shifts will take much longer. I ran the CenterForce Dual Friction clutch also and I liked it.
Engine: 355 carb'd
Transmission: 5spd
going to try the MCL-75225 - McLeod Super StreetPro Clutch Kit,leaving the 3:08 and will run a 235/55/16 street tire,this is a driver and drive to work weekly(160mile round trip)so do like the 28mpg
the trips to the track will just have to happenon test n tunes,on race nights the ol GreeNader will be under me
the trips to the track will just have to happenon test n tunes,on race nights the ol GreeNader will be under me Supreme Member
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
I spent the better part of a decade putting 50+ passes a year on Spec clutches on sticky tires with 1.5xx short times.
They performed very well and the ONE time I had a problem with a brand new clutch, they took such good care of me I swore I'd never use another brand.
I picked up a billet twin disc setup from them last year and I love it so far.
At lower power levels I've used the Spec Stage 3 and Stage 3+ and they're great.
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Centerforce DF held ok at the strip but didn't like slicks. It would slip if I went hard off the line and I could smell it bad. Easy pedal great daily driver.
Ram Powergrip HD held with slicks but the pedal effort was so high my clutch hydraulics blew out. It may be better now that I have a metal master cyl but it was a bear to deal with in traffic.
Was considering Centerforce DFX but ended up going with....
Mcleod RST. It is a dual disc organic clutch. It holds great at the track. In fact almost too good. There is little, make that no slipping it. It has moderate effort, somewhere between the Centerforce and the Ram. Don't notice it unless sitting for a long time at a drive through. The only negative is it is a solid hub disc. It transmits harmonic vibrations to the transmission at certain load/rpm points. Causes "gear rattle" when lugging in 3rd or 4th at ~2000rpm. Avoidable but something you should know about or you may think something went wrong. It is also expensive at ~$800 but if you are like me and put 4-5 clutches in looking for the right one it's a bargain.
If $$ is tight and you don't mind the effort the Ram is a tough clutch and ~$400. If you have mechanical clutch linkage you don't have to worry about the hydraulic issue.
If you are in between the Centerforce DFX may be a good option at ~600.
330hp_91RS
Jul 22, 2003 06:43 AM
