Adjusted/Repaired TV cable on 700r4, shifting late
Old Mar 20, 2018 | 09:16 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Hey guys, I've been driving with my TV cable rigged to the throttle (and it shifting fine) for awhile now, and today while replacing the fuel injectors I replaced the plastic clip that was broken on the tv cable and readjusted it. Car loves the new injectors, but acts like she wants to hang onto gears and shift later than she should.
I followed this guide-
https://www.thirdgen.org/forums/tran...djustment.html
I pushed in the adjuster tab, pushed the slider back, and pulled the throttle to WOT (as far as it would go) and heard the click. Then I released the slider and the throttle. Where did I go wrong, or do I need to dial it in some more? I've read thru other threads where guys had to dial it in another click or two. Any suggestions? Got a lot of driving to do tomorrow and don't want to burn anything up....except rubber
Old Mar 20, 2018 | 11:25 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Re: Adjusted/Repaired TV cable on 700r4, shifting late
Just have to test drive it till you find the sweet spot. one click at a time.Has happened to me a few times. But in the future when you get it perfect, take a spray can and spray it on the tab so next time if it happens again you know exactly were it goes.
Old Mar 21, 2018 | 10:46 AM
LiveIt!'s Avatar
Hey there I appreciate the reply, I adjusted it again to 2 clicks this morning and went for a short test drive, shifting SMOOTH now! Can't wait to hit the highway!
Old Mar 28, 2018 | 07:43 PM
Mark4132's Avatar
Where do you get your cables? I just replaced it on my camaro,but I bought one from AutoZone and I'm pretty sure it broke.
R/T-Z28
Mar 3, 2013 06:17 PM
louflemm
May 5, 2012 11:32 AM
Darkshot
Feb 18, 2007 10:12 PM
a91rsinvegas
Sep 23, 2006 10:20 PM
GASGZLR
Mar 10, 2004 03:04 PM
