tilton adjustable master with hydraulic release bearing adjustment
Old Apr 25, 2018 | 10:29 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey guys, i'm trying to run this through my head and i think i know the answer but need confirmation
i'm using a tilton 6000 hydraulic release bearing and have just installed a
hawks/tilton adjustable master cylinder.
the instructions for the release bearing say it needs a pedal stop to prevent over extending the release bearing.
if i'm adjusting the master cylinder to just release with around 1/4" more movement. would this mean that i don't need the pedal stop as i adjusted the master to not throw more then what's needed to release the clutch?
these parts are all new and i'm setting them up.
Old Jan 31, 2024 | 04:43 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Re: tilton adjustable master with hydraulic release bearing adjustment
Did you ever figure out if you need a pedal stop?
I have the 4th gen pedals but even third gen pedals have a built-in stop. I was wondering if that would suffice.
Old Jan 31, 2024 | 09:09 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yes, you need a pedal back-stop so to never bottom the piston in the clutch master cylinder. The Tilton has 1 inch of stroke.
Furthermore, adjust the pedal height to not over stroke the clutch. You can figure out where is clutch release by lifting the rear tires off the ground and having a person try to turn the tires. The tires will turn when the clutch releases.
Old Feb 1, 2024 | 12:31 AM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
I figured I was going to need to figure something out soon. Any ideas on how/where to put one? I thought about drilling/tapping a hole in the part pointing to an arrow. I could then attach a bolt and a few nuts. Then I would still be able to utilize the safety switch but would need to remove the cruise disengagement switch. Maybe the pad at the base? However, I'm pretty sure I'll probably need to space out my safety switch so it fully engages.
Old Feb 1, 2024 | 12:42 AM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Found a few on eBay that clamp to the arm...That might be an option.
Old Feb 1, 2024 | 01:49 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You said you have 4th gen pedals.... ? it has a built-in back stop already.
Old Feb 1, 2024 | 11:45 AM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Confused and relieved at the same time.
I also have an adjustable master and had planned to wait until I set everything up to see if I need to make any adjustments or add any additional pedal stop modifications.
Old Feb 1, 2024 | 03:30 PM
clubber's Avatar
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
Yes, the 4th gen has pretty much the same backstop as the 3rd gen pedals
Aviator857
Sep 23, 2018 07:36 PM
Jupiter
Nov 30, 2011 10:16 PM
BlueZee28
Oct 20, 2009 11:05 PM
1bdbrd
Oct 7, 2009 09:23 PM
Sonix
May 9, 2008 12:29 PM
