Clutch Master Cylinder Problem
Old May 13, 2018 | 01:30 PM
IROC G's Avatar
Car: 85 IROC
Engine: 305 HO
Axle/Gears: 3:73 posi
I stepped on the clutch this morning, something Popped, and the pedal went to the floor and stayed. A bit of looking and I found the top of the clutch master cylinder rod had come off the stud on the clutch pedal arm.
Visibility and light (and eyesight) are poor but on the top of the rod it looks like there are three tabs on a plastic(?) bushing and one of those appears bent or broken. Is this common and more importantly can these bushings be bought short of robbing from a new master cylinder?
Suggestions for a fix will be appreciated.
The master cylinder is five years old. The car is an L69/T5 1985 IROC.
Thanks.
Old May 13, 2018 | 02:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Clutch Master Cylinder Problem
Yeah it's getting hard to find but the bushing is available, if I can find one I'll post the part number
Old May 13, 2018 | 03:14 PM
IROC G's Avatar
Car: 85 IROC
Engine: 305 HO
Much appreciated, thanks.
Old May 13, 2018 | 06:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Gm 14091384
Old May 13, 2018 | 07:50 PM
IROC G's Avatar
Car: 85 IROC
Engine: 305 HO
Thank you.
Old May 13, 2018 | 09:27 PM
Drew's Avatar
Can also use the style clip the brake pedal uses.
Old May 14, 2018 | 07:21 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I prefer coming up with a bronze bushing to replace the plastic (be creative, use a Dremel) , and adding a retainer clip from a brake pedal rod (I have migrated from the GM clip to aftermarket.)
Old May 14, 2018 | 06:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
I cut the stock pice into a simple bushing and used an E clip. Works fine
Old May 14, 2018 | 07:24 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i just installed a new master and the freaking rod popped off, which i knew was going to happen i use the metal clip the brake pedal uses and cut the plastic "teeth" off the pedal
nchezey
Interior Parts Wanted
Apr 30, 2015 10:19 PM
tmork454
Aug 15, 2013 03:45 PM
berlinettakid
Jun 9, 2004 12:05 AM
