Transmission issue ?
Old May 25, 2018 | 11:27 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
I have a 85 z28 with the 700r4 and today my 4 gear started to lag a bit. When getting into it seemed like it would grab but when slowing getting into it, it would shoot up to 3500 rpm then drop to 2500 rpm before it grabbed. Checked trans fluid and it seemed a bit low put near a quart then i adjusted the tv cable and its shifting better then it was but still seems like its lagging a bit more then norm. Any ideas ?
Old May 27, 2018 | 11:22 AM
Re: Transmission issue ?
Anyone ?
Old Jun 1, 2018 | 08:35 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Sounds like your clutches may be starting to go. What was the condition of the fluid? You may want to drop the pan and change the fluid
Old Jun 1, 2018 | 08:51 PM
Fluid looked good and didn't smell burnt
Old Jun 5, 2018 | 06:54 AM
Pro Built Automatics's Avatar
If you want this transmission to last for awhile, add the Corvette servo and boost valves to this transmission. Add the .500" main boost and the .296" intermediate/reverse boost valve. This will speed up the shifts and make the clutches and band last longer. This can be done without removing the transmission.
Old Jun 6, 2018 | 12:36 AM
Thanks. Thought about adding the corvette servo. I'll have to look into adding the valves
rads84n94camaro
Sep 13, 2011 06:25 PM
dredre08
Jun 1, 2010 01:16 AM
slow_90firebird
May 19, 2008 12:55 AM
Psycho_91Camaro
Apr 17, 2005 03:06 AM
S10Wildside
Mar 28, 2003 07:13 AM
