difference between VSS part numbers
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i need a new vehicle speed sensor. i see that there are 2 options for 1991 700r4. they are both for electric speedometers. part numbers 10456088 and 10456089. the speedo gears i am using are 15 drive and 43 driven.
10456088 link-
https://www.amazon.com/ACDelco-213-197-Original-Equipment-Vehicle/dp/B0016I5AK0/ref=sr_1_2?s=automotive&ie=UTF8&qid=1531099260&sr=1-2&keywords=10456088
10456089 link-
10456088 link-
10456089 link-
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Re: difference between VSS part numbers
Someone else should verify, but my understanding is the 6088 is for 3X tooth driven gear and the 6089 is for 4X tooth driven gear. I hope so, because I purchased a 6089 so I can install a 44-tooth driven gear to correct for my 2.73 to 3.23 rear gear swap.
Awesome thank you. Where did u get that page from?
mult68
Aug 3, 2009 07:47 AM
25THRSS
May 8, 2004 05:17 PM
