Question on the 700R4 trans
Old Dec 6, 2018 | 07:50 PM
Ct1987's Avatar
Hi, I have a 1987 formula with the 305 engine and the Rochester cc carb. I would like to change to an EFI system. My question is, if i remove the carb with all the sensors that the ECM needs, what will happen to my transmission. I understand the ECM controls the lock out, is it using input from one of the carb sensors??
Thanks in advance for your input.
Louis
Old Dec 6, 2018 | 07:57 PM
NoEmissions84TA's Avatar
Re: Question on the 700R4 trans
Start here: https://www.thirdgen.org/torqueswitch/
Old Dec 11, 2018 | 09:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Louis
TCC lockup is mostly a function of throttle position (TPS), and vehicle speed. The new EFI system should be able to take care of lockup. If not look into a different EFI system.
RBob.
Old Dec 11, 2018 | 03:02 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
The "TV" (?) valve will need to be addressed.
Old Dec 11, 2018 | 06:18 PM
Ct1987's Avatar
Thanks, guys for your input.
Louis
zeek
Feb 14, 2017 07:01 PM
85TransAm_FaQ
Nov 3, 2005 08:31 AM
mdurbala
Sep 20, 2005 05:59 PM
400Z28
May 12, 2001 11:58 PM
