Gear ratio
Old Dec 16, 2018 | 01:48 PM
Mr.250r's Avatar
Car: 1988 Iroc
Gear ratio
Can anyone confirm this is indeed a 4.10 ratio gear set? Doesn't seem to be stamped like stock set that I'm used to at least but maybe the aftermarket does it different. It's the only numbers I can see decoding to that.
Old Dec 16, 2018 | 02:50 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Gear ratio
Count the number of teeth on the ring gear. Count the number of teeth on the pinion gear. Divide the teeth count of the ring gear by the teeth count of the pinion gear, that's your gear ratio.
Old Dec 17, 2018 | 09:18 AM
big gear head's Avatar
Re: Gear ratio
Yeah, it's that simple. Count and divide.
Old Dec 17, 2018 | 10:03 AM
Mr.250r's Avatar
Car: 1988 Iroc
Re: Gear ratio
The whole point was to avoid that just because no big deal I ran the #s it's a motive gear 4.10 set, I appreciate the help though
Old Dec 18, 2018 | 03:47 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Gear ratio
https://www.summitracing.com/parts/mgr-g875410
Here it is based on the part number from the gears
Old Dec 23, 2018 | 06:12 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Gear ratio
7.5 anything past 350hp and sticky tires the pinon gear with drop teeth like crazy..just sayn..
twigger
Feb 17, 2012 05:49 PM
raidercelticfan
Mar 9, 2008 11:50 PM
Slow Iroc
Aug 16, 2001 01:50 PM
hookin88formula
Nov 27, 2000 07:54 PM
