This seems to easy...
Old Jan 9, 2002 | 11:41 AM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
TransGo® has been improving automatic transmission Performance Control and Durability for ever 35 years. If you want performance shifts, more firmness, Shift Control and Durability using normal hand tools and without removing the transmission, do what the professional mechanic has been doing for over 35 years...INSTALL TRANSGO
A transgo kit can be put in a 700R4 tranny without removing the tranny?
Old Jan 9, 2002 | 12:43 PM
Mo's Avatar
Mo
yep
Old Jan 10, 2002 | 08:50 AM
87ROCZ's Avatar
Ok...so how hard is this to do?
Just wondering if tranny removal is needed/necessary
Old Jan 10, 2002 | 09:29 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Shift kits are pretty basic to install with the trans in the car.You'll need to drop the pan and remove the valve body.(Hope you don't mind bathing in ATF)For me the toughest part is holding up the valve body with one hand and starting the bolts with the other,so it might be easier with some help.
It's easier with the trans out, because you can turn it upside down, but I've done it both ways.
-Rich-
Old Jan 10, 2002 | 03:14 PM
TBI305Camaro's Avatar
the trans-go comes with a really good video that shows you step by step what to do...doesnt look to hard i just havent got around to it yet mines still sitting in the box in my room
sailtexas186548
Apr 8, 2022 08:54 PM
BadRiggins
Aug 29, 2013 10:33 PM
smev
Sep 2, 2011 04:20 PM
Firebat
Fabrication
34
Dec 8, 2010 11:19 PM
terrorsquad77
Jul 26, 2010 12:21 PM
