Running a two piece rear main seal crank in a 1 piece rear main seal block
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
The tile pretty much says it, what all is required to convert to a two piece rear main seal crank from 1 piece?
My understanding is that I will have to:
Get a seal converter/assembly (bolt on, no machining required?)
Get a neutral balanced flywheel/flex-plate to replace the one piece one I currently have.
And thats it? That seems too easy...
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Running a two piece rear main seal crank in a 1 piece rear main seal block
Why would you want to downgrade to the two piece main seal?
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
most high end cranks are designed for a 2 piece, so to run the crank I want I need to
It also lets you run a neutral balance flywheel
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
As mentioned you can get the rear seal adaptor for either for either the early pan or the late pan, I prefer the late pan as you can use the one piece oil pan gasket from GM = no leaks.
Also you will need an alignment mandrel to locate the seal adaptor.
I have used a lot of the later one piece rear seal blocks and used a 2 piece rear seal crank.
a slightly confused mind wants to know. 😁
You want the later 1-piece rear seal block because the machining is much more accurate than any 70's block.
Not that a 70's block can't be corrected by a very competent machine shop, but you will pay dearly for that.
The better choice then is a DART block.
QuickStyle
May 27, 2008 01:24 PM
ChevyCamaro4lif
Dec 25, 2003 05:24 AM
ok good to know
