Going from TH700R to Manual on a daily driver, stock HP - which one?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
T5 or T56 or ?
Pluses and minuses of each?
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Re: Going from TH700R to Manual on a daily driver, stock HP - which one?
What size motor? How much do you want to spend?
Also do you have the tools to tune it after the swap?
Engine: 350 TPI L98
Transmission: WC T5
I want to spend as little as possible but want it to work perfectly. It's a stock 89 LB9 (TPI).
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
T-5. easiest conversion.
Car: `86 SS / `87 SS
Use your local resources to pick up everything from a parts car. 88-92 WC T5 from a 305 car, the pedals, switches, and pigtails, 88-89 PROM (will need to !VATS) and when you're all done, keep the TCC wiring from burning on the exhaust.
Stock stuff works and would meet you needs. A 2.66 / 0.50 T56 is not what you will want to drive with a 305 and 3.42 rear. The only offset of T56 cost is fuel savings w a possibly taller 6th, so along your goals, keep it simple as stock.
Tootie Pang
Jun 23, 2017 11:00 PM
HiPerf_Chevyman
Mar 31, 2014 04:28 PM
Stangski09
Oct 30, 2010 10:38 AM
Boogie123
Sep 30, 2009 11:08 AM
Matt86t/a
Theoretical and Street Racing
May 1, 2003 07:25 AM
