FABbot Kit to bolt an LS engine to an AR5 5speed possible in a third gen?
Old Apr 5, 2019 | 01:04 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Looking to see if this path would be possible for an alternative to a T56? We all know T5’s are weak but apparently AR5’s can handle around 700 ft/lbs. I guess my question is to the transmission guys who are familiar with these transmissions is it physically possible to fit this transmission into a third gen?
https://www.fabbotfab.com/products/a...ission-adapter
Old Apr 5, 2019 | 07:08 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: FABbot Kit to bolt an LS engine to an AR5 5speed possible in a third gen?
The non-GM versions of that trans. are not a problem size-wise, unless you count shifter area.
I like their use of the 4L60 bell as an interesting re-use.
As for the ratios of the Solstice box, no thanks.
Old Apr 5, 2019 | 08:45 PM
Mortorq's Avatar
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Are there different versions of the AR5 trans that have different torque ratings?
The AR-5 is a 5-speed manual transmissionmanufactured by Aisin. It is designed for longitudinal engine applications and can handle up to 260 ft·lbf (353 N·m) of torque based on existing applications. [1]
General Motors used the AR-5 as RPO MA5.
Old Apr 5, 2019 | 11:17 PM
jmd's Avatar
jmd
OEM ratings and aftermarket ratings are different. You won't see an OEM TR6060 listed as 700lb-ft, but the T56 Magnum (a TR6060) is.
Their claim of the AR-5 being a 700lb-ft trans on the referenced site is a stretch. The bearing package is good, but the gearset just isn't as robust as a T56, let alone a TR6060.
Old Apr 6, 2019 | 04:59 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Definitely not a great transmission. On a cold day I couldn't get mine to go into 2nd gear in my Solstice
New2Chevy
May 4, 2010 04:45 AM
mscott
Dec 23, 2006 11:13 AM
wgripp
Jul 20, 2005 02:46 AM
Andy Fanshawe
Oct 11, 2004 08:53 PM
92zeddar
Sep 20, 2001 12:35 AM
