Rear Differential gear oil change
Car: 1987 Chevrolet IROC-Z Camaro
Engine: LB9 > L98 5.7-liter V-8 TPI
Transmission: MD8 4-Speed Automatic MX0
Axle/Gears: GU5 3.23 G92
I’m planning on changing the rear differential gear oil. I have never done this, and have read to use two different types of products. ACDelco 10-4051 GL-5 80W-90 Axle Gear Oil – (23 oz.) and ACDelco 10-4003 Limited Slip Axle Lubricant Additive – (4 oz.) How much of each do I need and what is the mixing ratio?
GU5 – 3.23 Rear Axle Ratio
G80 – Differential, limited slip
Thank you for your help!
James
James
Transmission: 5-Speed Manual
Re: Rear Differential gear oil change
All 4 Oz.Of The Additive Go In ,Then Fill With The Gear Oil To The Bottom Of The Filler Hole.
Don't make the popular mistake of using gear oil that already contains the LS additive and add an additional bottle of LS additive, in effect doubling up on the LS accidentally. Read the label of the gear oil you're going to use before you add additive.
Limited slip differentials don't limit slip too well when there is too much LS additive.
James
Thanks guys!
Jboat87
Feb 7, 2015 08:55 AM
Brad91Rs
Mar 12, 2002 06:12 AM
brockrodgers
Jan 3, 2001 02:42 PM
