Speedo Gear Change W/ Speedometer Change
Car: YTG Camaro
Engine: 383
Transmission: TH-350
I am getting ready to swop the speedo gear after a recent rear end change. I also want to replace the speedometer for one that goes higher that 85mph. Is it better to do them at the same time?
'84 Camaro 327ci Bored .030 over w/ 5.7" Rods. Large Jouranl 327! 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B&M Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
It is still under construction @ www.iserv.net~brodgers
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can do them at the same time, or do one and then do the other whenever you feel like getting around to it. The two procedures have nothing in common.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
