bleeding slave cylinder for TR6060
Old Apr 7, 2019 | 10:00 PM
Richard Douglas's Avatar
I am putting an LS-3 andTR6060 into a 1948 Studebaker , engine and trans are out of a 2010 Camaro SS. I believe I got the slave cylinder bled. I press down on clutch 2or3 times I have a hard pedal(like stepping on the brake pedal) but no matter how hard you press the clutch does not disengage. I am using a small wilwood single reservoir master cylinder. Any Thoughts?
Old Apr 7, 2019 | 10:27 PM
Re: bleeding slave cylinder for TR6060
I forgot to mention the master cylinder for the clutch is under the floor of car,don't know if this makes a difference but it's lower than slave
Old Apr 7, 2019 | 11:13 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Volume and piston travel need to be sufficient volume to move the slave. Consult w the Mfgr. of your master.
Initial gap from bearing to pressure plate fingers can't be excessive. If it is a stock slave, PP, disc and flywheel, you're probably fine. But shimming the slave to remove excess isn't a bad thing. Stock style slave cylinders can, when compressed, have an 1/8" gap and work fine.
The OEM master and slave setup is not easy for everyone to bleed. If you can get a one-way valve on the slave, and push the fluid back to the reservoir repeatedly, you should get rid of all air easy. Vacuum pumps, pressure pots, and other wannabe methods do not pressurize the system when bleeding like the master cylinder will. Use it.
smokefan
Mar 16, 2010 11:31 AM
Tremo
Apr 20, 2006 05:47 PM
Buck89RS
Nov 18, 2004 12:33 PM
airbrushguy
Mar 17, 2004 10:54 AM
schrammer
Sep 30, 2001 06:36 PM
